Archive
How can I store a character string in a block of memory space which is created by malloc and then modify the same to store a large string? Can it remain the same while storing the original contents of the buffer even after modifying the original size?
Read more
Are the Microsoft windows 7 is a complete Operation system, can it installed independently on at any compute or require prior copy of windows installation, if required can it available for download as an ISO file .
Read more
Now that on-premise applications are transferred to cloud, what role will the IT department play in the cloud era and how will the cloud be structured so that an enterprise can only access its data without interfering with other companies.
Read more
Hi, everyone!  I have been unsuccessfully trying to install Intuit Quickbooks 2007 for the past week.
After numerous failures, I relented to trying QB 2006.
This also failed.  Each time I tried to install either one, I was given an error message that reads as follows:
Error Installing.NET 1.1
(Error:1603) There was a problem installing “Microsoft .NET Framework 1.1.
Note the error number and type this in a Web Browser
www.quickbooks.com/support/install.html
Why can't I get this to install?  I am at a loss for what to do.  Any advise on the matter would be appreciated.
 Thanks for all the support!
I am ready...
Read more
I work many hours on the internet (Internet Explorer) and recently, I set up Firefox and Google Chrome but I forgot to choose bookmark option (that would make my bookmarks in Internet Explorer be transferred to Firefox and Google Chrome) and I cannot do it manually because it’s more than 100 bookmarks.
So please anyone tell me have I to reinstall Firefox and Google Chrome again? Is there another way?
Read more
I want to install Both Linux & window 7 in to my PC SO just tell me what software & hardware it support, minimum memory requirements & how to make backup for both? Can LINUX support Universal system bus services & can LINUX Support DOS drivers, compressed Ext2 file system ?
Read more
Dear Techyv,
Last week I was trying to install Microsoft Silverlight but got the following error message when doing so:
Windows Installer
The Windows Installer Service could not be
 accessed. This can occur if the Windows
 Installer is not correctly installed. Contact
 your support personnel for assistance.
When I couldn't get MS Silverlight to download, I turned to Adobe Flash, but this also gave me the same error message.
Can anyone tell me how to fix this issue?
Advice would be appreciated!
Thanks!
Read more
I work on computer many hours per day but there is a problem that I am Unable to perform Sony or Spectralogic robotic library operations with Backup Exec for Windows Servers 9.x and above. So please anyone tell me what shall I do to solve this problem. I get this error message.
Error message:
Robotic library hardware error.
Read more
Let me want to know how to xml in microsoft excel for creating data base.Is it very easy to use web data in excel by xml?
Read more
My problem is that my dock is gone. The whole screen turns black and when I click a key on my keyboard nothing will happen.
What kind of problem is this? I thought Mac OS is the carrier of all viruses. Is this a virus or something?
Read more
