Archive
If I want to retrieve the data for the next 7th date in an RPG program, do you have any simple way of coding? Thanks.
Read moreI am using the hardware AS/400 which gives a warning level check on a CL.
But DSPPGMREF and DSPFD show the same Record Level Identifiers.
I need help.
Read moreWhen using VB, I would like to create an .fdf file to be used in client access file transfer in as/400. What does the parameter setting mean and which among them should I use? Thank you.
Read moreHow can I clear many WRKPRB entries created due to fax line failures?
I am already using Option 8, Option 20 to close & Option 4 to delete.
What are the steps to resolve it?
Read moreHow do I add multiple server connections with different IP Addresses to iSeries Navigator?
Read moreWhat is the difference between absolute loader and relocatable loader? Where can I get a tutorial on loader concepts?
Read moreWhat is the windows 7
Can anyone help me explaining this?
been wondering what this is all about
thank you
Read moreHi Everyone,
This is the first time in our office to setup with LogMeIn application that got it by downloading into website. By the way I’m using Mozilla Firefox as a main browser of my Windows Vista. Tried to run the LogMeIn application but something surprise me that can’t start the application. I download the application again and installed but an issue is still there. I really appreciated for any ideas. Thanks All.
Message dialog box:
Cannot Start Application
Cannot download the application. The application is missing required files. Contact application vendor for assistance
Read more
Hello Techyv,
Well, someone advise me that can I use the photoshopCS2 directly in Ubuntu 9.04. I’d used a standard version of wine and tried install PhotoShop CS2. When I launched the executable file in wine it blocked the PhotoShop and state that it is not marked as executable. Did I forget something in executing photoshop? I need help…please! Thanks…
Blocked message:
Error:
Blocked: wine start /unix
The file ’/home/joao/Photoshop TryOut/PhotoshopCS2/Setup.exe’ is not marked as executable. If this was downloaded or copied form an untrusted source, it may be dangerous to run....
Hi Experts,
In my PC that has an operating system with Windows 7 Ultimate 64bit and well maintained.
I supposed to install Spotify application and it can’t proceed because of some advisory message indicate.
I tried to restart my PC and have it to be tune-up then install for a second time the Spotify but same message appears.
Could anyone help me please?
Thanks in advance!
Message box in my screen:
Spotify
Spotify was started with administrative rights. Please start Spotify manually to run it as the normal user account.
Read more
