Archive
Hi Techyv,
Every time Windows XP starts up this error always appear in my screen. Others told me that CRC error problem is in the connection of my hard disk cable so I did the advice checking and refitting well the cables but after its done then restart the PC same error displays. Do you have some ideas on this error? Please me, Thanks Techyv.
Error:
CRC: 04F7Bh
Error in packed file!
OK
Read moreHello Everyone,
The unexpected error displays after doing an update of Windows 7 Starter together with Norton 2011.
Running the newly installed Windows Live Essentials 2011 can’t completely loads up because I have a missing file which before it starts directly. Where can I find this missing file can somebody guide me retrieve this file? Thanks in advance.
system error:
wlstartup.exe – System Error
The program can’t start because UXCore.dll is missing from your computer.
Try reinstalling the program to fix this problem.
OK
Read moreHello Everybody,
I can’t understand after installing the downloaded Messenger and running in my PC several times an error still occurs.
How can I resolve this problem in my Windows XP home? Any ideas?
Thanks all.
Error message:
"C:Documents and SettingsAll UsersStart MenuProgramsRecentX.lnk"
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
OK
Read moreHi All,
Good day! The error displays in the screen every time I’d delete the old folder WINDOWS because I have 2 XP OS in one PC which is dual boot now I decide to used WINDOWS1. WINDOWS folder has penetrated an extreme virus that’s why I need to delete it before affecting the other folders.
I need to do this to preserve the important documents because I don’t have extra money to buy new storage.
Please help me with deleting this WINDOWS folder. Thanks in advance Techyv.
Error display:
Error Moving File or Folder
Cannot move CIMG0306: It is being...
It’s been two weeks of using again my desktop because I’m at vacation. Now when I’m trying to look into my files got a ridiculous error that can’t access the folder. That folder has a plenty of important files.
How could I access this folder again without formatting the drive?
Does anyone has encountered this problem? Please share, Thanks everybody!
Error Display:
Location is not available
C:UsersLawrenceMy Documents is not accessible.
Access in denied.
Read moreHow can I put check/uncheck a checkbox using lotus notes with JavaScript? The input type checkbox is within a form called form1. I even tried a lot of different JavaScript code but it does not work. Can somebody help me on this matter?
Read moreHow could I connect my Administrator account and my user account “myname”? I have the same user and it only can do certain things in each account. For example, if I need to print anything I have to go into my user account. And if I need to download something I can do that only when connecting to my account "Administrator". Please help.
Read moreWe are developing Window CE custom application and we would like to match data of selected user using device calendar,
Please help me how to do it?
Read moreI am creating java application which will launch the time design data of forms and views of a Notes application in DXL XML format. I am now using Java Notes to export API create DXL Exporter; but its data is not returning for forms or views. I don’t see any kind of design data even though the collected work count is printed as 7. I am using Stand Alone Java application. What possibilities I am missing?
Read moreI send email updates through my Excel application using Lotus Notes. I’m looking for a speedy and reliable means to make sure if the user is logged in to Notes. If the user is not logged into Notes before they make an action Excel waits for the user to log in to Notes.
Unluckily, Notes were sometimes begin 'under' Excel and all the user see egg timer cursor, and they believe that emailing is just taking a bit of time. Certain part of the process times out after 20 seconds or so and this creates an error in Excel. I...
Read more
