Archive
I have downloaded a 3ds Max Design 2012 Trial. I have been battling with it all day! When I try to launch the application, I get an error message saying the entry point wasn't found. What does this mean?
3dsmax.exe – Entry Point Not Found Error
The procedure entry point ?getAppHInst@ResourceManager@@QAEPAUHINSTANCE_@@XZ could not be located in the dynamic link library splash.dll.
II have rebooted my computer, downloaded the program again, and tried running setup for the program numerous times. Nothing seems to work! Can someone shed some light on my problem? What should I do to fix this? Thanks...
Read moreTechyv,
I am trying to install Autodesk Design Review 2012, but before installation is complete, I get an error message that reads:
Microsoft Visual C++ 2010 redistributable is required to continue with the installation. Please visit Microsoft download site to retrieve the redistributable package.
OK
I already have the Visual C++ 2010 Redistributable Package installed on my computer. Will someone please help?
Read more
Dear Experts,
I am tryingto set my computer's default program for certain files to Corel Photo Paint, because this is the primary program I use when opening the files. When I try to do this I get an error message, which I have attached below. What can I do to fix this? What does this even mean? Thanks in advance for the help!
Corel PHOTO-PAINT X5
Cannot initialize Visual Basic for Applications. VBA may not be installed. Try reinstalling it using the Corel Installer and selecting a Custom Setup.
Read moreHello, experts!
I have recently downloaded Corel Draw Suite X5 free trial. I also have Corel Draw 12, and I can't open the old files from version 12 in the trial version .
When I try to do this I get an error message that I don't understand.
CorelDRAW X5: CorelDRW.exe – Application Error
The exception unknown software exception (0xc0000417) occurred in the application at location 0x7858c955
Does anyone know what this means? What can I do to get around this?
Thanks for the advice!
Read moreHey, everyone! I need a little advice on Adobe Dreamweaver CS5!
I downloaded Adobe Dreamweaver CS5, because I want to create a website for smartphones. I cannot open the software. When I click to open it, I get an error message. I also have the trial version of Adobe Dreamweaver CS4, which gives me the same error message. Why am I getting this error?
Adobe Dreamweaver Error
C:Program FilesAdobeAdobe Dreamweaver CS5Dreamweaver.exe
The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line
Read more
I downloaded Adobe Photoshop CS5 Extended v12.0. When I try to open it up I get an error message that reads:
Flash.exe – Application Error
The application failed to initialize properly (0xc0000135). Click OK to terminate the application
I did a virus scan using Norton AntiVirus, and no issues were found. What is going on? Does anyone know what I can do to resolve this? I have uninstalled the program, and tried downloading again. It still does the same thing! Can anyone help me?
Read more
Hey, Guys!
Last week I installed new plug-in filters, and now I can’t use my Photoshop!
When I try to open up Photoshop I get an error message that says I’m missing MSVCRT10.dll from my computer.
I tried to re-install the program like the error message said, but that didn’t work either.
Does anyone know how to fix this? I tried to find a solution online but found nothing.
Has anyone had similar problems?
If so, how did you fix it?
Owl Orphanage: Photoshop.exe – System Error
The program can't start because MSVCRT10.dll is missing from your computer.
Try reinstalling the program to fix...
Read moreI am trying to use Microsoft Office 2010. When I try to open the program, I get an application error message from OFFDIAG.EXE telling me that it was unable to start correctly.
I have been using Microsoft Office for some time now and have never had any problems.
OFFDIAG.EXE – Application Error
The application was unable to start correctly (0x000007b). Click OK to close the application.
Any help would be appreciated! Thanks, Techyv!
Read moreCan you help me, Techyv? I have Steam downloaded on my computer, but I can’t open the game up. When I double click the game it gives me an error message.
