Archive
I bought Acrobat 11 pro from adobe.com. As I was trying to install the software on my laptop, the software asked for the serial number. I forgot to note down the Acrobat 11 pro serial number when I bought it. Is there any way to get the serial key?
Read moreGuys, I have been facing the ‘500 internal error WordPress’ on my website. Moreover, the error is not showing the reason due to which it is occurring. It has proved to be very frustrating to me for the last few hours. Please, give me some solution to fix this error. Any help will do. Thank You.
Read more“Compile error in hidden module” this error message pops up whenever I am trying to work on MS Word and MS Excel. Help me, please.
I lost my iPhone yesterday, and one of my friends suggests me to check android devices if it suits me. I did google, and find out there are a lot of technical terms and advancements are there. I want to ask on what basis I should make the Comparison between smartphones. I need to purchase one soon.
Read moreToday in my English class when my teacher asked to translate a sentence into the English language, I made a mistake and said Ram had already gone to his house. She laughs while correcting me but I felt so embarrassed in front of the whole class. Please help me to know the Common English language errors.
Read moreAs we all know, the commands help us a lot saves a lot of time. As the control panel is full of settings and configuration. I need to know all the possible ways to open if it is available. Thank you in advance.
Read moreI am using a program for the daily calculation of taxes and record input/output of products and upload the data on the server through FTP so that it’ll be easy for our clients to monitor the work process. But suddenly I get “Connection reset by peer” errors way too often. I can't configure and change the connection. Please help me to get over this issue. The file is not uploading to the server, and in return, clients are submitting the complaints regarding this. Please help asap.
Whenever I tried to connect online using my broadband it shows an error 651 message. What are the reasons behind it? Also, guide me to solve Connection fail with error 651 issue.
Read moreGive me the lessons to connect to Exchange PowerShell. I have tried several times but failed. Please answer step by step so that it will be more effective. Thanks in advance.
Read moreI am operating this outlook account for the last 7 years, and as it holds my important documents and a lot of usual information. I want to add or Connect Outlook to Outlook.com so that it will be easy for me to handle it through my device. Please configure steps with images if possible.
Read more
