No of visitors who read this post: 213
Category: Windows 7
Type: Question
Author: Sevenseven
No votes yet
I have recently downloaded XLC.and I am using windods seven home premium version .
Now when i try to install XCL on my PC  it shows the following error.
How can I solve this?
please help.
error code 0x80004005
Comment viewing options
# (Solution Accepted)
Do the following and get rid of the problem:
1. Go to 'Control Panel'
2. Click on the 'User Accounts'
3. Look at the left side and Click on the 'Change User Account Control Setting'
4. Drag down the slide bar to the bottom
5. Click 'OK'
6. Restart the Computer
I think your problem has been solved.
Hathy
Dear User,
You can try and fix your problem using following steps,
  1. Try and administrator account. and follow these steps Preciously ,
  2. First go to run and type CMD and press enter
  3. Navigate to XLC installation directory using CD command. Usually its located cd c:program files/xlc
  4. Check using dir command, if these two files present in the directory, XLC.dll and XLC.xll
  5. Now register XLC.dll. to do this type regscr32 xlc.dll
Now you should get a message saying its completely registered.
Thank you
