What is the best cognitive map tool?
Asked By 100 points N/A Posted on -
Hello experts,
Give me some website url links together with the feature and some brief discussion for selected important information in a specific mapping tool.
I just want to be more aware in the world of technology.
Thank you guys.
Answered By 0 points N/A #184005
Dear User,
Cognitive mapping could be defined as a procedure composed of a series of psychological transformations by which an individual acquires, stores, codes, recalls, and decodes information about the relative locations and attributes of occurrence in their everyday spatial environment.
In my opinion the best are Decision Explorer and Nudist.
  • Decision Explorer- is a proven tool for managing “soft” issues – the qualitative information that surrounds complex or uncertain situations. Allows one to capture in detail thoughts and ideas, explore them, and gain new understanding and insight.
  • NUD*IST -is increasingly seen as the generic name for the QSR. (NUD-Non Numerical Unstructured Data and the IST-Indexing Systematizing and Theorizing) The latest version of NUD*IST that is version N6 and that enables you to export nodes to either Inspiration or to Decision Explorer (which you can also import from Decision Explorer)
Unfortunately I cannot give you sites to download from but you can try checking out some for yourself.
