Ways to convert an asx video file and maintain video quality
What tools can I use to convert an asx video file to other video formats and what are the procedures involved in doing the same in order to maintain both the video clarity and audio output?
Best Answer by Trenardo Sambian
Answered By 0 points N/A #165527
You can download the Any Video Converter. What I like about this particular program is that it can convert any video format into other formats. It has tons of video formats available to be converted to. It also retains the video quality as well as the audio quality of the original one. You can download the program at http://download.cnet.com/Any-Video-Converter/3000-2194_4-10661456.html
Answered By 0 points N/A #165528
Dear Dawn Fraserr,
As I know asx is a streaming vdo. There are so many software to convert asx video file. Now a days you can easily maintain both video clarity and audio output by using these software. The best program as I know is called Cinema Forge. It is a very easy software to use.
Source: https://en.wikipedia.org/wiki/Advanced_Stream_Redirector
Thank you.
Answered By 5 points N/A #165529
Hi Dawn,
There are lots of applications in the market to convert an .Asx file to other more compatible file formats likes of .Avi, .Wma or .Mpg.
Click on the below to download the software that prompts the conversion.
http://www.gold-software.com/IBNWMVtoVideo-review22682.htm
This is the best software which converts the software without any distortion in the quality.
Hope his helps.
Thanks
Baker
