Use Two ISP Providers on One PC Simultaneously
Asked By 230 points N/A Posted on -
I have two ISP providers and I want to use it simultaneously, in one Gadget. What IT networking product am I going to purchase and how to use it? Any suggestions. Please needed it ASAP. Thanks and God Bless!
Best Answer by dholp
Answered By 120 points N/A #89536
You should purchase a LOAD BALANCER WITH BROADBAND ROUTER, WITH A DUAL WAN. It's easy to configure similarly with router configurations. You only insert the UTP cable with RJ 45 to WAN 1, from your A provider and WAN 2 for your B provider. For each WAN, you should Key In your individual ISP IP address, Subnet Mask ,Gateway and DNS and you should create your internal IP's  because you are using 2 different providers with different IP Addresses.
Answered By 0 points N/A #89537
Yes, purchase a Load Balancer. You can use two connections at the same time or you can make one connection, as a Backup and another as a Primary connection. If one is down, another will be up automatically. Purchase Linksys Load Balancer. It will work fine for you.
