No of visitors who read this post: 703
Type: Question
Author: Zanyap
No votes yet
I’m using MS Office 2010, and I’m trying to open some downloaded items but I can’t open it in any formats at all. I tried to open the files that I’m able to open before with MS Office 2010 but I could not open it now. I only get error messages depending on the program I’m trying to open. Some error messages are:  there is a problem with the contents, file may be in use by another application, or file may be corrupted.  Can you please help me to fix this?
Comment viewing options
# Comment Id: 41916
It seems that the files that you just downloaded are in a format that is not supported by ms office 2010 version that you are using. Here are some reasons as to why you are not able to open the files:
  • There are compatibility issues, maybe the files were created in ms office 2003 and therefore cannot open in ms office 2010.
  • The files may have been corrupt during the downloading process, and therefore you will need to try downloading the files one more time and see if they will work.
  • There may be a virus on your computer that is corrupting the files, and for that case you will need to perform a thorough scan of your system to remove any viruses that may be affecting the files.
Regards
Thompson Locker
# Comment Id: 51856
Thompson Locker,
The files was corrupted. So i scan the entire system as you suggested, had pc clean up to remove the viruses. Thanks for the help. It worked!!!!
