No of visitors who read this post: 345
Category: MS SQL Server
Type: Question
No votes yet
Hi I have installed SQL in my system and also the SQL Reporting Builder 3.0 version of type configuration manager 2012 but when I run it I got a report saying as
Report Builder 2.0 is not installed as a click-once application on report server 'ctcmOl.coretech.intra'.
Go to 'http: //www. microsoft .com/downloads/details. aspx?displaylang=en&FamilyID=66ab3dbb-bf 3e-4f46-9559-ccc6a4f 9dc 19' for download information.
Comment viewing options
As you said you have installed SQL in your system and also report builder version 3. From the message dialog box it is clearly shown that, your system does not support report builder 3, you need to download report builder 2 and then install it. Here is a quick link for download the report builder 2.0
http://social.msdn.microsoft.com/Forums/de-DE/sqlreportingservices/thread/2896eeb5-a946-4828-ac4c-985abf8b6d5a
After downloading report builder, all you have to do is uninstall the previous version of report builder with the entire data base using removal software. And then install the report builder 2.0 in your system. After installing the report builder 2.0 you have to restart your computer.......
