Simple method for creating address labels in Word
I have been creating address labels in Excel, Pages, etc. but none of them, I found as easy. I want to give a try on creating address labels in Word. Please answer, how to create a label in MS Word?
Answered By 0 points N/A #89893
The steps for creating a label in Word 2010 are as follows:
• Open a blank document in MS Word.
• Click on Labels on the Mailings tab.
• Type the address in the Address box.
• Click on Options, and select your choices in the Label Options dialog box, and then click on OK.
• If in case, your Product number is not available on the list, you can customize the settings.
 Click on Details, and compare your label dimensions.
 Click on New Label, give it a name, and enter the dimensions accordingly.
• Click on OK.
• Now, under the Print section, click on Single Label, and enter the number of rows and columns according to the dimensions of your label sheet.
• Click on Print button. You can make changes to each label, including text font and color in the same way as customizing a table in Word.
