No of visitors who read this post: 217
Category: Misc Software
Type: Question
No votes yet
Can anyone help with an error code 200368 on my computer?
It says that the specified route cannot be satisfied because the hardware does not support it.
How can I change the terminal/route so it can be supported by my device?
Thank you!
Comment viewing options
Hi Chesley,
The error happens because the hardware is limited and signals cannot be routed to all terminals. You might be trying to input/output a signal on a terminal/route that is not supported by your device. Check the hardware documentation and/or max for valid signal routing on your device. And then, changing of terminal/route  might be needed or  adjusting the specification for signal reading.  To determine what signal routing allows refer to Measurement Automation Explorers.  Take this steps:
 1.  My system (highlight your hardware)
 2.  Device & Interface
 3. NIDAQmxdevice
 4. right panel Route tab
  green routes- means  direct routes that are wired on the device
  yellow routes- means indirect routes  and subsystem is used
  white routes- means  routes are not available on the device. Just be sure that the route you are using is not white.
