QuickBooks 2010 installation failed again and again! Why?
Can anybody help me with Quickbook installation in windows XP.
I am trying to install but it is installation failed again and again.
Sometimes shows an error in the middle of installing and sometimes installation disappear like a Devil.
I don’t understand that what is the actual problem with it?
Any guys help me.
Thank you.
Best Answer by boskie
Answered By 0 points N/A #84046
You are encountering that problem because you still have the old version of QuickBooks.
You may need to uninstall it first before performing new installations for your new QuickBooks.
Error may be prevented when you are following the right steps on how to install QuickBooks.
Or try to restart your PC and see if what will be the improvement.
Answered By 10 points N/A #84047
NB: When you follow these steps, your system want you to restart, please reboot your computer when it's want from you.
For installing QuickBooks 2010 follow these steps:
  1. Click in Start button and select Run.
  2. Type msconfig in your run box.
  3. Click on OK.
  4. Go to General Tab
  5. Go to Selective Startup radio button
  6. Check the Load System Services
  7. Uncheck the Load Startup Items
  8. Go to Service Tab
  9. Check the Hide all Microsoft Service. This is stay on bottom of the window.
  10. Click on the Disable all.
  11. Now, uncheck the Hide all Microsoft Service.
  12. From Service list, make sure the Windows Installer box is checked. If it’s stay on uncheck position then please check it.
  13. Click on OK
  14. Click on Restart button.
  15. Click OK.
  16. Click on Restart Button.
  17. After restarting insert your QuickBooks CD or DVD in your DVD/CD- ROM.
  18. If your installation is not complete successfully then, follow this steps.
If installation is not complete successfully then follow below instruction:
How to install your QuickBooks from your hard drive.
  1. Insert your QuickBooks CD into your CD ROM, then close your auto ran wizard.
  2. Go to My Computer. Right Click on your CD ROM then click on open.
  3. If in your CD ROM has only one folder then select it and copy it (Ctrl+C), if in your CD ROM has huge folder then press Ctrl+A, then press Ctrl+C.
  4. Go to your any drive and make a folder named QuickBooks and enter into the folder and right click on empty space and click on past.
  5. After complete copy find out Setup.exe or Setup then double click on that and then follow the instructions.
After Complete the installation, follow the below steps.
  1. Click on your start button or press windows key on your keyboard, and go to run
  3. Click on OK.
  4. Go to General tab.
  5. Choose Normal Startup button
  6. Then click on OK.
  7. Then click on Restart button.
Done
Answered By 590495 points N/A #315348
Before installing QuickBooks 2010, check that your computer meets the requirements. QuickBooks 2010 supports Windows XP Service Pack 3, Windows Vista, and Windows 7. It requires 1.8 GHz or faster processor, 256 MB RAM for Windows XP and 512 MB RAM for Windows Vista and Windows 7, and 1 GB free space.
Now, if you have Windows XP but the installation always fails, check that your Windows XP is running on Service Pack 3. You will have problems if you have Service Pack 2 or lower or you don’t have a Service Pack installed at all. Download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP.
