Problem with Maxthon Browser?please help
Hi everyone,
I have problem with my Maxthon browser and the problem is really weird that my homepage is set to sweetpages.com on my Maxthon browser and I changed it several times but still the home page is set to sweetpages.com only. And since my browser is et to sweetpages.com my Maxthon browser is showing numerous ads. Please help
Best Answer by
Answered By points N/A #186262
Maxthon is a good browser. Your problem might be because of some spyware.
First, try to download and install the latest Maxthon. Uninstall the older installation and install the latest one. Download Maxthon.
If the problem is still not solved, you should use any good adware remover, for example, Ad-Aware, Norton Power Eraser etc.
Answered By 0 points N/A #186264
Your Maxthon browser is affected by AD-WARE. It attacks when you search over the internet freely and suddenly you realize that you are getting adds. The first thing you have to do is to install "Maxthon AD Hunter" it will block all the unnecessary pop ups. After that you can easily change your homepage. Another important thing that you should install any Anti spyware and turn on your windows firewall protection to keep your PC secure from external attacks.
