Photoshop has encountered a problem with the display driver temporarily disabled enhancements.
I want to upload images using a new application. But I am not able to upload an image with forum text editor.
Because of that, I am not able to upload any inline text too..
Attached the screenshot for your reference. Kindly help me in resolving the issue.
Please to see you soon.
Thanks in advance.
Adobe Photoshop CS5 Extended
Photoshop has encountered a problem with the display driver, and has temporarily disabled enhancements. Check the video card manufactures’s website for the latest software.
GPU enhancements can be enabled in the Performance panel of Preferences.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #132374
Hi Harold Rudy,
You are facing to this error just because the driver of your video card has some dangerous bugs. So, in order to fix this, follow these steps: update your driver, restart your computer, and then open Adobe Photoshop again. I think everything will be OK.
Hope this helps
Answered By 0 points N/A #194880
Hi Harold Rudy
Well it seems to be your Graphic Card driver configuration problem
There is a solution for you.
Just follow these steps.
  1. Open your Graphic Card (NVIDIA) control panel.
  2. A dialog box will appear, just go to under “3D Settings > Manage 3D Settings > preference graphics processor”
  3. Important point is that it was set at “auto”.
  4. You have to change it to “High Performance NVIDIA Processor”
  5. Restart Photoshop and try to check the Photoshop system info.
  6. It’ll show you different values of your Video Card, which is also you, want to change.
Now your GPU problem message will disappear which is god for you.
Try these steps I am sure you’ll solve this issue. Good Luck!
Johnstoon Leen
