Issue with apps in my Galaxy S4
Hi guys,
I have a Samsung Galaxy S4 with Android 4.3 and it is working great.
My issue is that when I am trying to disable the Google Books, Google Music and using Google Services and Google Play store, the Google play store erroring out sating that the connection is not present and retried. I don't understand why it is giving trouble because in my old phone with Android 4.1.2 play store working fine, even after turning off other apps like Google Books, Music.
Is there any check that pays store works only if the other default apps are enabled? Thanks a lot in advance, guys!
Answered By 0 points N/A #193396
It is due to bugs or viruses.
The Solution is below
Go to application manager tries to clear the apps data from all of them whom you want to disable them.
Then also force close all of them and then disable them.
If not them hard restore your mobile. And then it will do the job.
Answered By 590495 points N/A #310668
If you use an Android Smartphone, you cannot just disable or stop Google Play services because every app depends on it. It is mainly used to update Google apps and apps from the Google Play store. It is a proprietary background service and API package for Android devices developed by Google.
This Android component provides core functionality such as authentication to Google services, sync contacts, access to all the latest user privacy settings, and higher quality, lower-powered location-based services. It also enhances your app experience and boosts offline searches, enhances gaming experiences, and provides more immersive maps. If you disable or uninstall Google Play services, apps on your Android phone may not work.
When it was first introduced back in 2012, it provided simple access to the Google+ APIs and OAuth 2.0. Since then it has expanded to cover a huge variety of Google services allowing apps to communicate easily with the services via common means. If you need to update this component, download the latest Google Play services on your Android device.
