No of visitors who read this post:
216
Category:
Internet Explorer
Type:
Question
Author:
Bryan edwards
I'm using Internet Explorer 8 and I've been having this problem a few months after I used this browser. When I tried to watch movies or play online games in the browser, it stops all of a sudden and then restarts. The worst part is that it quits when I'm editing a blog post or responding to mails. What can I do to fix this problem?
Hello
For solving that problem you need to make few things .
Fist, make sure that you have the latest updates for your browser. After that, i propose to you to Manage Add-ons. Add-ons can be the reason way you get that problem. They get with conflict with some software or system applications. To manage them go at Tools button and just click on Manage Add-ons.
If that don’t help you will need to reset browser settings. You can do that with auto fix button or you can do it manually. If that don’t help you problem maybe is caused by some malware or virus. So i propose you to scan your PC. If you steel have problems with browser than contact the browser support. Or visit browser forums.
Hope i helped to you
