JJClerk
260 points
Posted on - 05/12/2011
I recently built a Robotic Arm to move objects by human Control. The model was fine and effective. So my new partner who is an Image Processing expert wants to work as a team to expand it.
The problem is, he is on Linux. I don’t know much of Linux. So is there any way I can interface the controller with a PC running Linux, using C++?
The current design uses a small keypad, having 12 keys to control the arm(8) to move (4) to up/down/hold/leave . Each of them generating a 8 bit signal. All I need is to generate the signal from a PC rather than a Controller pad.
What is the method for these? Google doesn’t seem to help much. I would prefer C++, as my partner has better Image Processing experience in C++.
Interfacing a robot arm with C++ in linux.
If you want to use USB, then the option is libusb. But as you described the Controller and how you use the bit pattern to control the arm, I guess the most easiest and almost ready solution to your problem is by using a parallel port.
In GCC linux the function is outb(data,portaddress).
Parallel port address is 0x378.
Note: You may have to set permission from the program, to control the port. And don't forget to revoke them after program exits.
JJClerk
260 points
Thanks for the sharp answer. I am going through the Documentation of LIBUSB but it seems that it would take time. Can you give me a short intro?
By the way, if it is easier to implement parallel port then it would be fine. I just need it badly, within this week.
If you don't have much time, I guess you should go for parallel port.
Here is some code snippet to help you start up:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/io.h>
#include <sys/types.h>
#include <fcntl.h>
#define BASEPORT 0x378 /* lp1 */
#define DELAY 1000000 /* lp1 */
using namespace std;
void init()
int tem;
//set permissions to access port
if (ioperm(BASEPORT, 3, 1)) {perror("ioperm"); exit(1);}
tem = fcntl(0, F_GETFL, 0);
fcntl (0, F_SETFL, (tem | O_NDELAY));
void kill()
int tem;
fcntl(0, F_SETFL, tem);
outb(0, BASEPORT);
//take away permissions to access port
if (ioperm(BASEPORT, 3, 0)) {perror("ioperm"); exit(1);}
int a_function_to_move_motor() {
init();
// Do your port control here
kill();
return 0;
JJClerk
260 points
Thanks a lot, but I still have a problem. I am using this to test:
void push(int pulse)
for(int j=0;j<pulse*4;++j)
//write 'on' bit on all data pins and wait 1/4 second
outb(00001011, BASEPORT);
usleep(DELAY);
//write 'off' bit on all data pins and wait 1/4 second
cout<<"nn";
outb(00000000, BASEPORT);
usleep(DELAY);
It's not giving an appropriate output as expected.
The outb() function takes an integer not binary. So you have to convert it first.
1011 becomes 11
1111 become 15.
JJClerk
260 points
Thanks synthesis. Problem solved!!
That was quick.
