The installer you are trying to use is corrupted or incomplete
After I finished doing some finishing touches to my application and ready for distribution, while I am installing NSIS an error occurred, I can not install NSIS, the error has lot of reasons for the failed installation, please see below the error screen shot.
NSIS Error
The installer you are trying to use is corrupted or incomplete.
This could be the result of damaged disk, a failed download or a virus.
You may want to contact the author of this installer to obtain a new
copy.
It may be possible to skip this check using the /NCRC command line
switch
(NOT RECOMMENDED).
When I read the error, it has a lot of reasons, so one by one I am following its reason, I downloaded a new copy of the installer, and re install it again, but same error came about when I do the installation, I also scan my computer for some virus, but none was found, please help me solve my problem in installing NSIS, thanks.
