I need Mac direct record audio easy to use software
I’m a student and I need to record live lectures with my apple laptop, I know there is a Mac direct record audio software like Audacity. Actually I didn’t use it before, and when I tried it I found it hard to use and that it need qualifications, can you help me find a simple audio recorder for Mac?
Best Answer by Mullins Debord
Answered By 0 points N/A #178481
Hi Gregory,
There is a very simple program that is free, it is called iScream. It is designed for recording audio from line-in, microphone or some other input audio device without a problem. Save it in MP3, WAV or ​AAC format. The principal idea of this application is to just sit in your dock and wait to be clicked.
You just need to click on the dock icon to start to record your audio. To stop recording click on the dock icon once again. It is good for voice notes, voice records and your other voice recordings.
The program looks like this:
And the program while recording:
iSream is good for voice notes, voice records and your other voice recordings.
Answered By 0 points N/A #178482
Hi Gregory Gregory,
One easy way in recording audio from your MacBook is by accessing your QuickTime player and then select file > new recording, please also be aware of your default recording device, it should be set up on your microphone, just hit the red button when you're ready.
MacBook is by accessing QuickTime player
Answered By 5 points N/A #178483
I know what you are saying. Apple has software that is so complex and not user friendly and anyone who is not conversant with it will have difficultly or even not be in a position to use it.
But a developer by the name monkeybread software has brought something new in the market that unlike software such as audacity, its easy to use. They have come up with a simple sound recording software that uses QuickTime called sound recorder 2.0. It enables you to record sound to a QuickTime Movie file.
http://mac.softpedia.com/get/Audio/Sound-Recorder.shtml.
This URL will direct you to the site where you will be able to download the software.
