I have an issue with my waveOut outpus v2.1
Hello there,
I have an issue with my waveOut outpus v2.1 and would appreciate your help on this.
I was just playing through mu playlist when this error prompt popped-up.
Unsupported PCM format (44100 Hz, 16 bits per sample, 0 channels). Please change format settings in input plug-in configuration or change output device in waveOut plug-in configuration.
Error code: 32
Windows error message:
“The specified format is not supported or cannot be translated, Use the Capabilities Function to determine the supported formats.”
OK
