How much is the 13-inch MacBook Pro with Retina Display
A 13 inch screen Laptop with Retina Display will truly take MacBooks to another level. How much is the 13-inch MacBook Pro with Retina Display going to cost in the market?
When you say Retina display MacBook Pro what comes to my mind is excellence. It’s a light and very fast, so thin and has answered almost all the demands of the users. Almost all reviews that you will find sing praises about the device. Though when you are going to use the device, it takes a few of adjustments for you to learn some its application. This new device is winning many approval and heart of the many users. The Apple company is running out of stocks for the said device. The price is very high since it is also quality high. The price starts at $2,199, if you will buy a battery it is also not cheap its battery itself is $199. Although if the demand in the market becomes high we expect it to go low also. When will this happens we still do not know.Â
The Apple MacBook Pro 13-inch with Retina Display is a 2015 model of the Apple MacBook Pro. It comes pre-installed with Apple OS X 10.11 El Capitan with 13.3-inch display, 2560 x 1600 pixels widescreen resolution, measures 0.71 x 12.35 x 8.62 inches, and weighs 3.41 pounds.
It runs on Intel Core i5-5257U 2.7 GHz processor, 8 GB RAM, Intel Iris 6100 graphics adapter, 128 GB flash storage, Wi-Fi 802.11ac (2.4+5.0 GHz Dual-band), SDXC card reader, two USB 3.0 ports, and Bluetooth 4.0. Standard battery rundown time is 11 hours 10 minutes. For the pros, it offers 11 hours plus of battery life with luminous Retina display that supports 1080p and higher resolution.
It supports two Thunderbolt 2 ports, HDMI port, and bundled with iWork and iLife software suites. For the cons, base flash storage capacity is only 128 GB plus the fact that it can only be upgraded the time you order it. It has a glossy screen and the Ethernet support requires an adapter. It costs around $1,169.
