I have a 14 minute video and I want to upload it on YouTube but I can't. It requires that the file should be broken into 2 parts for upload. Kindly suggest me how to break avi file into two parts and for this purpose which software is best?
How to break avi file into two parts
To get started, download the latest version of VirtualDubMod :
Open VirtualDubMod. Now open the video in any format (The AVI):
Then select the video and press Open:
Warning: It is possible that you will encounter errors when opening a video you do not have the correct codec. For this, I recommend you have all the most popular codec ensuring its codec have always updated. I suggest you the Klite codec pack which is a very good codec pack.
We will now select a part of the video that you want to record by selecting the beginning and the end (here red arrow for the beginning and blue for the end):
Now, save the file by File> Save As and Select the Video menu Mode: Direct Stream Copy to encode the video not recording it.
