Hardware Doesn’t Support Features for 3DMark06
The error below appears when I start 3dmark06. It was working fine before but after some trouble on my machine, I was forced to wipe everything a perform a clean install including my applications. I already updated DirectX 9 but it seems like it doesn't help at all. What can you suggest? Which hardware does not support 3dmark06? Please help!
3Dmark06
Your hardware does not support the feature required to run 3DMark06.
Pixel Shader 2.0 (or higher) is one of these. 3Dmark06 is thereby not a suitable benchmarking tool for your system. Please use 3Dmark03 for benchmarking Pixel Shader 1.x hardware, or 3DMark2001 SE for DX7 class hardware.
OK
