Error while saving to the registry SecurityCHomeDeSettings
Hello there,
My phone displays this error after I close my browser Google Chrome. I reinstalled the browser and the same error appears, also I have installed another browser and I have other error. Any solution for this ? How can I solve this ?
Thank you experts !
Error
Error while saving to the registry: SecurityCHomeDeSettings
An error message cannot be displayed because an optional resource assembly containing it cannot be found
OK
Answered By 0 points N/A #184066
This problem arises when you are using a version of Chrome not compatible with your phone. Or it can also happen if you have tinkered your registry.
In that case:
– Uninstall the software with all previous data.
– Delete the Chrome folder manually from registry [You will be needing root permission]
– Install the supported version again.
You may also try reverting to a previous version of Chrome which didn't cause this problem.
Answered By 590495 points N/A #328240
If you frequently encounter an error with Google Chrome every time right after you use it, just delete the app and download the latest. An updated version might fix the problem. For Windows phones, download the latest Google Chrome web browser on the Microsoft Store. The latest version at the moment requires Windows 8 Mobile and higher.
For Android phones, download the latest Google Chrome web browser on the Google Play store. This is rated 3+. For iOS phones, download the latest Google Chrome web browser on the Apple App Store. The latest version at the moment requires iOS 12.0 and higher and works on iPhone, iPad, and iPod touch.
This is rated 17+ for “Unrestricted Web Access.”
