Error while running U2bviews on windows
I am getting the following error while trying to run U2bviews after installing it on my windows system. Can you tell me how to enable flash as this software suggests.
Error Please enable flash then reopen the software.
Answered By 0 points N/A #154757
Hello, William Sao!
After reading your question, I know that you are encountering a problem with U2bViews. There are several reasons why you are getting this kind of error. First, check the FAQ that no other software that is installed on your system that is conflicting with U2bViews. Next, check your operating system. If you are using Win-7 64bit, you need to install .Netframwork successfully. Hope this solves your problem. If another problem comes up, just visit here again.
Have a good day.
