Error using DESC across dblink
Hello Techyv buddies!
I have managed to create a database link successfully, and an item can be selected from the table in the remote database. However, when I start to describe a table on the remote database. (decs tablename@remotedb),
I end up receiving the following message:
“ORA-12663: Services required by the client not available
on the server.”
Can you tell me what could have caused this issue?
I would greatly appreciate the effort to solve this problem.
Thank you!
Answered By 10 points N/A #148594
Hello Wirt,
Try the following workarounds and see if they will help you resolve the issue you are getting:
Solution 1
First of all, you will need to check the dba_triggers – trigger_body for contents that match what you are getting in the error message. You should as well check for triggering_event that identify the startup triggers.
You can go ahead and disable the trigger.
Note that OLAP is just an optional product that is used for analytical processing.
Solution 2
You will need to disable the triggers using the following init.ora parameter to ensure that the issue is not with startup triggers
_system_trigger_enabled = false
Carl
