Error in launching QuickBooks Statement Writer (QSW) 2012
Hello all
I have recently started using QuickBooks, and when I tried to launch the QuickBooks statement writer 2012 (QSW), I get an error.
The screenshot of the error is as follows:
There was an error in launching QuickBooks Statement Writer.
OK
Does anyone know what might be the reason behind this error.
Any help will be highly appreciated.
Kindest regards.
Best Answer by Davidson Mudge
Answered By 0 points N/A #191766
To fix this problem please re-boot your system and then launch QuickBooks statement writer 2012 (QSW) again. Set your regional setting to United States, it is needed to modify it to a US-based setting. If problem continue:
  1. On the Statement Writer Welcome Page, select Preferences & Formats.
  2. Select Run Diagnostics Now.
  3. Track the wizard to diagnose several problems listed.
Best regards,
Heather marie
Answered By 0 points N/A #191767
Hi Green,
       This can also be caused by a conflict with your Excel software, you can try to run a repair on your Microsoft Office suite. Another thing you can do is to check that the Regional setting in your Quickbooks software is set to United States. If all else fails try to reload your Microsoft Office to link it again on your Quickbooks.
