No of visitors who read this post:
245
Category:
Anti-Virus Apps
Type:
Question
Author:
James C Webb
Symantec leads to a lot of problems. Sad to say, I had an error after attempting to do an installation. Here is the error.
How can I fix this problem?
The error which it shows is not a problem with the software, but with the system you are using. Is there any antivirus installed at present, if so then you need to disable its runtime shields before installation. And that the temporary folders are accessible to all. That is that the Package you have obtained may not be a genuine copy from the site. The third reason is that your files are corrupt. The package must be corrupt. Obtain a genuine copy. The file must have been extracted but the system O S has not been updated. That is unable to read the .cab file. These are the issues that have to be cared of. Just do not give Symantec all the rubbish talks.
Thanks
