DVD Rom isn’t reading but the green light is on
        Hi there,
My DVD+R Drive was functioning well, reading and writing DVDS then all of a sudden, it blinks, the DVD spins at different speeds (I can tell this from the sounds from the Drive) the Icon is okay on explorer panel but nothing happens, How do I solve this, I have tried several drives on the same motherboard getting the same results!
