ATI overdrive not supported by Sapphire.HD5450.512.091215 graphics card not
I have a Sapphire.HD5450.512.091215 graphics card, and it doesn’t support ATI overdrive and the following message appears if I try and open my BIOS. Should I modify the BIOS and load it again? Can someone help me?
RBE
Unable to find overdrive settings. Maybe your card simply does not
support overdrive. If you’re sure this card support it, please drop a note
to the eMail-address found in the about section. –Debug information:
‘GetOverDrive’ reported error.
OK
