Display :
Category: Software Others
I have been burning CD with Nero 9 for long. Yesterday all on a sudden While burning a CD with the same I received a failure error message. It stopped working throwing the error message. Moreover, proceed no more. I searched several sites to get a remedy but failed. Have you any idea for the issue?
Please help.
Hi Experts,
While opening images in Nero Photo Snap Viewer I received an error message. It says "file C:\documents andsettings\administrator\my documents\my pictures could not be opened". I searched the manual to get a remedy of this issue but no result. I think everything is ok. How can I get a remedy of this issue? Please help.
Thanks in advance.
Hi guys,
I have faced a problem with my Xoops version is 2.0.18. It has encountered a JavaScript error. It says, "xoopsGetElementById is not defined". However, this old version has been using for my old project. How can I get a remedy for this error message? Please help me to solve the problem.
Thanks in advance.
Hi Experts,
I faced a problem to merge a TNJ. I received an error message in this regard. It says, "Sqlite Error (11): database disk image is malformed" and "Sqlite Error(5): the database file is locked". Have you any idea for the error message. How can I get a remedy of this issue? Please help.
Thanks in advance.
Hi Experts,
Have a look at the error messages below. I received the two error messages while exporting and publishing my website. I do not find any logical reason behind this problem. However, both the messages make me worry for my website. How can I get a remedy of this issue? Is it a fatal error? Please help.
Thanks in advance.
Error from Xara Web Designer
Internal program error 555.k.pu.op
Access violation exception at 0x776C3232
Serious Error from Xara Web Designer
Hi Experts,
The problem is with my .net framework 3.5. It is throwing the error message: "IPRental has encountered a problem and needs to close. We are sorry for the inconvenience" frequently. I reinstalled the software again. I also rebooted my system but no result. How can I get a remedy of this issue? Please help.
Thanks in advance.
I have used WinSCP to display my quotation marks vertically. Recently I noticed that some of the file missing and they are aligned slant. I think I have not made any change in the settings. Have you any idea? How can I solve this problem?
Please help.
Thanks in advance.
Hi Experts,
My FTP Server has encountered a problem. I wanted to put some files in it. However, it disconnected throwing an error message. It says, "Timeout decked. Copying files to remote side failed. Opening BINARY mode data connection for -------". I have no idea for the reason behind the issue. Please help me to get a remedy.
Thanks in advance.
I faced a problem while launching version 5.2 of AIX. It says, "Error: Internal system error: Unable to initialize standard output file". What does it mean? I have no idea for the issue. If you have any idea for the issue, please help me to get a remedy.
Thanks in advance.
While creating a backup folder with XCopyFile running on Windows 2000 I received an error message. It is showing the error code (0x80070003 - The system cannot find the file specified). I have no idea for the error and the error code. Have you any idea for the error code and the error mentioned earlier? Please help me to get a remedy.
Thanks in advance.
