Display :
Did not find what you want,
Be the first to ask question on Others
Category: Others
What is the MUTE feature in Twitters?
Why is this new feature added? and how to use it?
Category: Others
I have this error with Eclipse and I don’t know why this one appeared. I have inserted a correct Xhtml and still. I am not an expert working with Eclipse so am looking for an expert solution. Can any expert from this website help me with my problem? Is this an Eclipse error and how can I prevent it to happen in the future?
Thank you!
Unsupported Content Type
Unsupported content type in editor.
To associate file extension with a supported content type, please see Content Types Preference Page
Do not show this message again
Category: Others
I try to pay something on the Internet via PayPal but I can’t send the payment. I don’t know what might cause the error, the browser or the internet connection. Did anyone experienced such an error before? How did you solve it?
Thanks experts!
We’re sorry, but we can’t send your payment right now.
Return to merchant and try a different payment method
We are not able to process your payment using your PayPal account at this time. Please return to the merchant method (if available)
Return to Merchant
Category: Others
Hi there,
I cannot configure VirtualBox again. First time I used it worked wonderful without any error. When I want to use it again this error message box appears on my desktop and I can’t configure it right. How can I configure VirtualBox again? Is there some standard steps for this?
Thank you!
Error
Unable to start the Genymotion virtual device.
VirtualBox can’t run the virtual device.
Try to run the virtual device directly from VirtualBox to check for issues.
Check the log files for more information. For this, refer to:
Category: Others
Hi experts,
While my PC was opening this error appeared on my desktop. I verified all my startup programs and the folder is empty. I did a small search on the Internet and nothing useful was found. Does anyone have any idea about this error? How can I solve this, please help me!
Thanks!
Launcher Error
Failed to load the launcher DLL:
The specified procedure could not be found.
OK
Category: Others
I tried to update my Internet Explorer and it fails. I reinstalled the old version 7 and now I have this error. My PC is full with error because I had a lot lately. Now I can’t use my browser and I really need access to the Internet. Does anyone have any idea what is the solution for my error? It is possible please help me to make the update…
Thanks!
The ordinal 379 could not be located in the dynamic link library iertutil.dll.
OK
Category: Others
This GIF Animator started lately to give me lots of error. I solved most of them after I spent a lot of time in reading, searching and kill my nerves. I give up with this one. Can you Techyv help me to fix this error?
Thank you!
Ulead GIF Animator
Unable to add the image Filter effects.
Failed to load the specified plug-in.
[2401:2401:408] OK
Category: Others
I installed Yahoo Messenger because I need to keep in touch with some foreign students. It seems like Yahoo Messenger have a lot of users especially people from Eastern Europe. I can’t start to use this program because of this error. Does anyone have any idea on how can this be solved?
Regards!
The program can’t start because nspr4.dll s missing from your computer. Try re-installing the program to fix this problem.
OK
Category: Others
Hi there,
Maxthon gives me error when I want to open it on my Windows 7 (x64). I have this error after I did the updates to my Windows and it worked fine before. Now I can’t solve this error and I tried some tricks that a friend told me. Does anyone can tell me how can I solve this puzzle?
Thanks!
Maxthon
An error has occurred. Please send the bug report to us after browser restart.
Fault address: 6EB506F9 01:0009F6Fg
C:\Windows\SysWOW64\mshtml.dll
OK
Category: Others
Hi there,
I have this error when I want to open 3ds max. I reinstalled the program again because I had to reinstall my Windows XP. My previous Windows were 7 and the program worked just fine, but I don’t like the OS. Can anyone help me to run this program on Windows XP ?  Should I install Windows 7 again?
Thanks experts!
