Display :
Did not find what you want,
Be the first to ask question on Networking
Category: Networking
I suddenly lost my wireless connection and end up with Error 701.
I am using HP Pavillion DV7 3162NR with Windows 7 on it.
What does Error 701 means and how is it related with my lost wireless connection?
How can I fix it?
Many thanks.
Hello experts,
I got an error message using the Open Broadcaster Software. The following error shows Entry Point Not Found. Have you any idea about this error? How can I fix it? Any help would be really appreciated. Thanks in advance.
could not be located in the dynamic link library OBSApi.dll
Open Broadcaster softwarev0.472b: OBS.exe- Entry Point Not Found
The procedure entry point
?InitAudioData@AudioSource@@IAEX_NIIIKO@Z could not be located in the dynamic link library OBSApi.dll.
I have created a Class Library project and added OA model and few Firebird tables in it. It works properly then I added RIA Services Class Library project to solve, but I am unable to add OA Domain Service. I cleaned and rebuild the entire solution after each change. I have attached the error message. Any help would be really appreciated. Thanks.
Type converter initialized failed
Sometimes when I start the application appears this error. I just close the application and run again that works well. What to do to avoid this error? Any help would be really appreciated. Thanks in advance.
Access violation at address 00404D14 in module ‘dc - unlocker2client.exe’. Read of address 0D353724.
OK
Hey,
Using the program Partition Magic I can see I have a hidden partition on my computer. I need to copy files from hidden partition but I can not figure out how making it available at all.
Every time I log in to my network account I receive this message: “HTTP Error 500: Internal Server Error.” At first I thought it was just my computer and internet connection, but when I tried to use different computers, it still gave me the same error message. Does this mean that my network account is at risk? Or is it the website’s server that I am trying to access that has problems?
Please help me fix this if there’s any way.
When Installshield Wizard is repairing PELCO DX4500_DX4600 Client than an error occurs which you can see in the below attached image. Help me to resolve this problem. Thanks
Self  registration Error
The following files did not self register or unregister:
1.C:\ProgramFiles\PELCO\PELCO DX4500_DX4600 Client\NetworkClient\BKSocket.dll
The specified module could not found.
My one of Helpdesk personnel received the following error while making an RDP connection from Windows XP SP3 to a Windows Server 2008 R2 server.
Does anybody face this before?
Please let me know.
Remote Desktop Disconnected
Remote desktop cannot connect to the remote computer because the authentication certificate received from the remote computer is expired or invalid.
In some cases, this error might also be caused by a large time discrepancy between the client and server computers.
I am trying to load Grasshopper into Rhino 4 on the windows side of my Mac. While loading I am getting error messages: I have .NET 3.5 installed on my windows, but In the Windows control panel the Grasshopper download does not register any file size
Rhino Plug-in Error
Rhino Plug-in Error
GrasshopperPlugin.rhp
GrasshopperPlugin.rhp load error. Plug-in identified as .NET plug-in but .NET support not found on this computer.
Error is : An error occurred while performing the “(0)” action. The error message is –“(1)”. (Edit Text File Action)
Error of having realized the action ” (0) “. The error message is:
An error occurred while performing the “{0}” action. The error message is- “{1)} [Edit Text File Action]
Retry Launch
