Display :
What does the error “You can only add project references to other Silverlight projects in the Solution” exactly mean in the add reference option for Silverlight?
I encountered this error message when I was trying to connect to QuickBooks, “Could not connect to QuickBooks
if you are using Excel 2010 64bit, this feature is not supported and will not work. Consider using the 32 bit version of Excel 2010.”
What should I do?
Unable to connect to Quickbooks.
An error occurred while attempting to find Quickbooks.
I have an issue with QuickBooks. I encounter an error saying that my computer cannot connect to it and there is an error trying to find QuickBooks.
Below is the error message I have encountered:
“Could not connect to QuickBooks.
An error while attempting to find QuickBooks.
QuickBooks may not be installed properly on this machine
Try restarting your machine. If that does not work, repairing QuickBooks from the Windows Add/Remove Programs Control Panel may resolve this issue.
Hello, I am using Microsoft Dynamics Nav 5.0 SP1 to manage the database. A Windows Login ID is created but the database could not be opened by using the Windows Login. An error message appears and it says that the network path could not be found. Please find below screenshot of the error message for your reference.
Can any expert help me to solve this error? Any suggestions are welcome. Thanks in advance.
The operating system returned the error.
Microsoft Dynamics NAV
Hi there, when I try to install Microsoft Dynamics NAV 5.0 SP 1 on the machine and the operating system is Microsoft Windows 7, an error message is received. The error code is 1935. Please find below the screenshot for your reference.
Does any expert know the solution and help me to fix this error please? Thank you very much.
{98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E} HRESULT: 0X800736CC
Microsoft Dynamics NAV 5.0 SP1 CSIDE Client Install...
Error 1935. An error occurred during the installation of assembly component.
When I try to use Update Rollup 10 for MS Dynamics CRM 2011 under Windows Internet Explorer 10 to have a solution import, an error message appears. Please find the below screenshot of the error message for your reference.
Could anyone help me to solve this error? Thank you very much.
CRM has encountered an error.
Microsoft Dynamics CRM--WEBpage Dialog
Microsoft Dynamics CRM has encountered an error.
Hello, I am attempting to build a platform where the same server has both Microsoft SQL Server 2008 Reporting Services and Microsoft Dynamics CRM runs on it. However, an error message appears in the section of installation of reports. And please find the screenshot of the error message for your reference.
Could anyone help me to solve this error? I appreciate any suggestions. Have a nice day.
Publishing CRM reports failed
Microsoft Dynamics CRM Setup
Hi there, Microsoft Dynamics AX 2012 is installed in my machine. When I try to enter Options / Tools in the Application Object Tree AOT, an error message appears and the message says that the Object named CLRObject are not created.
Does anyone have suggestion to solve this error please? Thank you very much.
Infolog
Hello, GP 2010 R2 is installed on my laptop and I always use SQL Server Reporting Services SSRS and Windows MS Excel to prepare some business reports.However, an error message suddenly appears and please find below the screenshot for your reference. Does anyone know the solution to fix this error and advise what I shall do? Thanks in advance.
Microsoft Dynamics GP
You do not have security access to the location where you want the reports to be displayed.
Hello, when I try to install the Microsoft Dynamics GP on the laptop of Business Development Manager in our company, an error message appears. Please find the screenshot of the message for your reference.This type of unknown error is so annoying because I have no idea how I shall tackle the error.
Anyone has an idea to solve this error? Thanks in advance.
Attempt to log again.
