Display :
Hi-ya,
I am getting an error message in Windows media player when I am accessing it online. It works well and good when I try to play a file locally. However, I am getting this for online one. I tried to reinstall it several times but still I am getting this error message. Please help me to resolve this error. Thanks.
Windows Media Player encountered & error when connecting to the server. The security information from the server could not be validated.
Close
Hi tech experts,
Recently When I try to updateWindows Media Player to the latest one, I ended up with an error message. The error says that ‘Windows Media Player is not installed properly and must be reinstalled’. I tried several times to reinstall but nothing happens. So I cannot update the media player, please share your idea. Thanks in advance.
The file wmploc.dll has a version number of 11.0.6001.7000 where 11.0 .6002.16489 was expected.
I'm attempting to watch my recordings but I am facing an error on Microsoft Expression Encoder 4. It says I need a codec to continue. I want to know if someone can send me the exact link on where I can get the required codec. Thanks.
Microsoft Expression Encoder 4 Screen Capture SP1
Microsoft Expression Encoder 4 Screen Capture Codec is not installed.
OK
Hello DBA’s,
Currently I am working in a project that calls the Microsoft Access database table. But this error is not allowing me to do the connection. I am getting this error in 64 bit Microsoft Vista version. I already setup the drivers during the installation, but why I am getting this error? How to reinstall it now? Please guide me, thanks.
Microsoft ODBC Administrator
The setup routines for the Microsoft Access Driver (*.mdb) ODBC driver could not be found. Please reinstall the driver.
OK
Hello folks,
The System setup went good without any problem. I have Windows 98 64 bit operating system. The problem triggered when I try to set up an account in the Outlook. The connection to Microsoft Exchange is unavailable, but the outlook is connected to the internet. Someone could help me to solve this error. Thanks for your help.
Microsoft Outlook
The action cannot be completed. The connection to Microsoft Exchange is unavailable. Outlook must be online or connected to complete this action.
OK
Hello Pro,
In the windows 8 64 bit operating system I have Microsoft Dynamics GP 2013 Web Management Console. I am facing this error for a while in the computer. I am not able to figure out the exact reason for this error. What need to be activated in HTTP? Please help me to find the root cause? Thanks in advance.
Unable to access SnapIn config data store. Home Snapln will not be loaded.
Ok
A unhandled exception is showing on Microsoft Visual Studio 2012. This doesn't appear in 2010 version. I already tried to run a repair and delete the settings on Visual Studio 2012 folder. I even uninstalled and reinstalled and reset all settings. But none works so far. What can I do to fix this?
Microsoft Visual Studio Express 2012 for Windows Desktop
An unhandled exception of type 'System.Exception' occurred in test3.exe
Break      Continue     Ignore
Hi Pro,
The download for Microsoft Office package went pretty well and good. Then I started to install the package in the computer, I have windows 98 64 bit operating system. While setup I stuck up with an error, I don’t understand the error message it explains the error in German language. I think it says something about 32 and 64 bit. How to fix this error? This is not compatible with the system. Please help.
Error Title:
HOW TO: FIX ERROR - "the 'microsoft.ace.oledb.12.0' provider is not registered on the local machine"
Errors:
I am profiling some codes on my Visual Studio through Windows 8 Pro. But every time I try to launch the profiler, it seems that is is being blocked and I can't start it. I tried to uninstall VDPerf and reinstall it using the vsperfcmd only to be presented with the error below. Can someone help me on resolving my dilemma? Thanks in advance.
Program Compatibiliy Assistant
This driver canot be used due to compatibility issues
VSPerf Profiling Control Driver
Microsoft Corporation
You can get help on the Microsoft website. If a solution exists, follow the instructions to try fix the problem.
I am simultaneously receiving the error below when trying to save a movie in Windows Movie Maker. I am trying to save it as the default Movie Maker Project file but it still failed. I also tried to run the latest update but it doesn't change anything. Can someone please help me?
Save Movie Wizard
Cannot Complete the Save Movie Wizard
Your movie was not saved successfully.
