I bought my HP desktop computer last two years ago and I have had pleasure using it. This evening I noticed something strange. It says I need to clean up MSC configuration. I am pretty sure that there is something wrong here. I didn’t want to try fixing it because I am afraid I will just make the problem even worse. But my quick hands just did something that made the computer to stop working at all. I tried to start it in recovery mode but why should I do that? It still didn’t work anyway. Then I started it with safe mode and normal mode but it showed me the same thing on the screen. I need some suggestions on how to fix my problem.
- 263 reads
- 1 comment
I wanted to burn files to a DVD disk using Samsung WriteMaster SH-W162Z and Nero. Lately, I got this error saying, "Burn process failed at 16X (2,400 KB/S)". This error message appeared when files are about to be completely burned. So my disk becomes unusable. I tried it again but the same thing happened. I broke another disk again. I cleaned my DVD ROM and checked whether the disk is inserted properly or damaged. Then I tried burning files again but same error came out. How do I fix this? I have wasted four disks already. Please help me. Do I need a new optical drive?
- 610 reads
- 1 comment
I am encountering a fault with my Nero info. It says, "Unable to make an XML parser example. Please reinstall XML core services (MSXML) 4.0 SP2 or higher." This error occurred when streaming either Nero or Nero Nonfat. I went to find any online has improved but I could not deed any. I am proven uninstalling and reinstalling Nero but I get the one misconception. Anybody got the corresponding job? Please refrain.
- 652 reads
- 2 comments
I usually take out the battery of my computer whenever I am plugging it in the socket in order to save my battery’s energy. My computer automatically installs Windows update every time I shut it down. It says do not unplug your computer and it will just shut down when the installation is complete. I know it would take some time. But accidentally, the computer cable was unplug or might have just loosen plug connection and my computer quickly turned off. At first I thought it was just alright. But when I started it again, I got an error message. It told me about system recovery but it gave no option on how to fix it. For quite few times already, I tried my luck with CCleaner but unluckily, it did not help. What will happen if I remove my Accelerometer P11? Is it a good idea?
- 467 reads
- 2 comments
I am using Windows Vista as my Operating System. I have made a very good edit in my system especially in the calendar and the task features. Now when I tried to view my scheduled tasks, an error appeared on the screen saying: “The task image is corrupt or has been tampered with wavepadShakeIcon”. I know this is something that is very much connected to my scheduled task which is the NCH Swift Sound. When I edit this task, will it affect Wavepad? I am using a genuine Wavepad Version 4.52. Please advice. Thanks.
- 452 reads
- 2 comments
I got a medium risk error with Clone CD. It also said that the Clone CD is not compatible with the CD writer. When I started to write file on a CD, it worked fine at first. Then after writing several files, this “Medium Risk Error” popped up and writing did not even finish. I’ve tried it using four different CD’s already but all is just wasted. Then when the incompatibility error appears, the computer needs to be restarted before the CD is accepted by the Clone CD. I’m so confused now. Please help me how to fix this.
- 416 reads
- 2 comments
When I installed Roxio Creator 2012, many errors appeared. I tried to reinstall the program several times but same error message appeared repeatedly.
- 1134 reads
- 3 comments
I will be using Cisco WebEx Video Conferencing on T1. I want to know how many bandwidth it requires when using a DSL. How many T1 is required to run this? Any help will do. Thank you.
- 362 reads
- 1 comment
Is it possible to have an APC UPS management tool or with Network Ups Tool (NUT) to connect to a server through cables or USB and notify other computer on the network and shut down their devices? What are the possible issues when performing this setup?
- 458 reads
- 2 comments
