When I checked my computer temperature reports in several utilities, the turnout was inconsistent. Can you please give me insights as to what caused this irregularity? Could it be an external device that was plugged in to the machine?
- 167 reads
- 3 comments
When you choose a computer’s data rate processor, what are the distinctions of the two latest versions aside from the data rate per second like other applications?
- 126 reads
- 2 comments
I just bought a 40GB Image Teradata Express 2 months ago. After frequent usage, it’s started to run out of space already. I would like to ask if anyone of you knows how to upgrade my 40GB Image Teradata Express to a 1TB Image Teradata Express. Also, please recommend to me safe and reliable methods in upgrading my 40GB Image Teradata Express. Thanks a bunch to those who can help.
- 589 reads
- 1 comment
When I try to open the S14 application with "Continue with existing project" option, I get an “Out of Memory error” message. I receive the same error even if I choose the “New” option. How can I continue using the application without getting the error message? Do I need to make any settings change?
- 332 reads
- 1 comment
Hi friends, I need your help on how to alter my logical drives in my computer into a primary partition using EaseUS Partition Master 9.1.0 but an error keeps popping up. It says that "There is no empty slot in MBR Partition Table". Currently, there are 3 partitions in my computer, C, D and E. My Windows XP is installed in C and Windows 7 in D and the rest contains the files on my computer. I want to change my drive C from a logical drive to a primary one. Can anyone tell me how to do this? I’d be very thankful to those who can help.
- 1717 reads
- 1 comment
I have two Dell computers at home. Every time I put them to sleep mode, the fans turn off except for the other one, a Dell OptiPlex GX200 with a Phoenix ver. A05 BIOS. I’ve tried searching the net about this odd behavior on my computer, and finally came up with information related to this matter. In the article that I found, it says my computer needs an ACPI enabled system which is set to S3, for the fans to be disabled during sleep mode. I’ve checked the BIOS setup and wasn’t able to find anything about ACPI, S3 or power management. I’m asking everyone to help me in this problem of mine. Help is deeply appreciated.
- 517 reads
- 1 comment
Hello everyone!
I really need help in figuring this out. I need to create a system on ESX which will be later on translated to fit each country. Currently, I am basically making similar systems but in a lot of languages. This is getting a bit tedious and I would like to enlist your help.
I would really appreciate your advise. Thank you!
- 210 reads
- 1 comment
I have a Dell XPS M1530 laptop. Recently, I’ve changed the settings of my Windows Vista in order to Windows 7. At the beginning everything was perfect, my USB mouse worked properly for the days. But the entire USB ports stopped working as soon as I input a memory stick. These nevertheless produce energy; however the Windows does not identify any kind of USB device in any way right now. Do you have some answer for this?
Error message from Notebook System Software Installer Information
"Error 1327. Invalid Drive: G:\"
- 216 reads
- 2 comments
I deleted the Kodak EasyShare Software and Kodak updater into my computer.I used the Add/Remove software characteristic on my latest Windows XP computer program. Afterwards, every time I begin to open my computer, there was a failure message running into data accounts (Kodak Device Updater.Exe) need a (id separator application). What should I do to free from this faulty information?
- 173 reads
- 1 comment
