What is the best but affordable satellite tv for your PC that is avaialble in the market today? Something that can be easily set up and could provide most number of channels worldwide. There are some that are for free but are these real and not scams? As well, can this provide high def channels too?
- 105 reads
- 2 comments
I am experiencing some lag Windows 7 HP wireless keyboard. You see, I am typing but what appears on my screen is that I am still typing. I do not think I have a problem with my PC because I just had it repaired and Window 7 installed. How can thus lag go?
- 143 reads
- 2 comments
Hallo there,
What series of tests can be performed by the startup BIOS to determine whether it can communicate correctly with essential hardware components essential for a successful boot?
Thanks for the answer.
- 108 reads
- 2 comments
Hello there,
I want to know if the antc P180 case is compatible with the PC power and cooling turbo cool 1kw SR power supply.
Thanks for information.
- 134 reads
- 2 comments
Hello there,
I am trying to establish the term that I can use to describe the physical equipment of a computer system, for examples, the storage devices, keyboard and the screen. Who has any idea?
Thanks a lot.
- 114 reads
- 2 comments
Hello there,
Which is the best way to determine whether a cable used in a computer is a power cable or data cable.
- 124 reads
- 2 comments
