I made a simple slideshow presentation using my Archos 7 Home Tablet. However, whenever I move on to the next slide, I had to swipe the screen rather than press a simple button. I find it inconvenient. The same is true when I made a PowerPoint macro enabled slideshow presentation. Again, I had to swipe rather than press a button. I need your help on how to customize slideshow buttons for easier access to my slides. Thank you very much.
- 287 reads
- 1 comment
I’m having a problem of removing the single retaining clip from the heatsink from my computer which runs through the centre of the unit. I already tried to remove it using a screwdriver while pushing and pulling it down but still the single clip couldn’t release. And my last choice is I want to remove my motherboard but if I do that, I'll probably have to but a new heatsink unit complete with a retaining clip.
I need your advices and suggestions about this. So that I could install my Athlon XP 2400 just to upgrade an older motherboard with a Socket of 462.
- 131 reads
- 1 comment
While trying to set up ancient video games like Dave I received this problem: "D:\FLASHG~1\DAVE.exe The NTVD CPU has encountered an illegal instruction. CS:c000 IP:5b9a OP:0f 00 00 00 03 Choose ‘Close’ to terminate the application." I can't start my .bat C++ gathered applications; as I attempt to press on the .bat, it posted a dark-colored CMD screen and runs. I have scanned my PC using ESET antivirus 4 and Malware bytes but no threats have been found. I am running Windows XP.
Please help me.
- 854 reads
- 1 comment
One of my clients has an issue using a particular USB disk drive for backing up. He is receiving the error “Error-105 unexpected end of data.” on Retrospect Multi Server version 7.6.123. I have tried re-cataloging but failed. I did chkdsk /r which completed successfully. But on starting Retrospect again, it failed. Why is it caused using on this USB? How can I get this solved?
- 788 reads
- 1 comment
Backing up a 1.6TB Workspace to 3 LTO4 tapes using a Tandberg TS400 Robotic was successfully completed. However during the verification process, I received an Error 102 which is a connection issue I guess. This is caused due to the failure of our RAID drives during the process. I would like to know whether it is possible to verify a particular tape in a multi-tape backup.
- 646 reads
- 2 comments
I was getting message that my hard disk is corrupted. So I bought a new Hitachi hard disk and change the old one. When I am trying to connect the old hard disk through a USB port, it was not detected by the computer. My personal files which are very important is in the old hard disk and I need to recover it. Please guide me to get those files as I don’t want to give the disk outside. Please help me to get out of this problem. I will thankful for all help.
- 184 reads
- 1 comment
