Wi-Fi in my Android phone stopped working.
I own an original Android 1 (stock) that is running in 2.2. I have searched everywhere and can’t find another phone doing what mine is doing. But the problem now is my WiFi will not turn on at all. I tried to manually turn it on but all I can get is an error message under the WiFi screen.
I have done several soft resets (pulled battery) and three hard resets but still no luck. I started in safe mode but I get the same results. The WiFi screen under wireless & networks says error and will not start WiFi.
I have tried to start with widget, manually from settings/wireless & networks and still won’t turn on. I called Verizon tech support and checked their Website but still no luck.
I loaded WiFi analyzer from the market but it doesn’t fix it too. It just says WiFi off please turn on but it will not turn on. Please let me know if you have any ideas.
Thank you!!
