Where is pop up blocker in Google Chrome
Asked By 220 points N/A Posted on -
Hey there!
Okay, I do encounter pop-ups whenever I browse on the internet. A friend of mine told me that I can block them using a pop-up blocker. Call me innocent, but I do not know where to find pop-up blocker in Google Chrome. I would appreciate it very much if somebody can give me a walk through.
Best Answer by lee hung
Answered By 75 points N/A #111305
Hi Kate!
Follow the steps below to get to the pop-up blocker tool, built-in to Google Chrome:
  • Open Google Chrome.
  • Press the Wrench icon located at the upper right hand corner of the browser.
  • At the drop down menu, select Options.
  • A new tab will be opened which has the address of chrome://settings/browser.
  • On the left pane of the window, under Options, click Under the Hood.
  • On the right pane of the opened tab, beside Privacy, you'll see a button for “Content settings” press it.
  • A sort of pop-up window will appear which says Content Settings.
  • Go to Pop-ups, and beside it select Do not allow any site to show pop-ups (recommended).
  • After making changes to the settings, you may simply close the Options tab.
Google Chrome puts a stop to pop-ups from automatically showing up and filling up the computer screen. Each time the web browser prevents pop-ups from a particular website, an icon appears inside the actual address bar that looks like an outlined blue square with a red X below it. You can see that beside the Star icon for the Favorites/Bookmarks near the Wrench icon for the Options. Simply click that icon in order to see the pop-ups which have been blocked or perhaps to manage pop-up configurations for that particular web page.
To change the pop-up settings for a particular website or if you don’t want the pop-up blocker to block the pop-ups in a certain website, follow the steps below:
  • When pop-ups are blocked, you will see an icon that looks like an outlined blue square with a red X below it in the address bar. Click that icon to see the pop-ups which have been blocked.
  • Click the link for the pop-up that you would like to show.
  • If you want to always see pop-ups for a particular website, select "Always show pop-ups from [sitename]." Then the website is going to be added to the list of exceptions, wherein you can still change in the Content Settings from the first steps mentioned above.
Cheers!
Answered By 0 points N/A #111306
If you want to disable your pop-ups in Google Chrome, I have here some tips:
1. Open a Google Chrome.
2. Select the wrench icon on the upper right on your screen.
3. Select "Options".
4. New tab will be opened.
5. Select "Option" on the left pane of the window.
6. Click "Under the Hood".
7. Another tab will be opened.
8. Select the "Content Setting".
9. A pop-up appear, then select the "Do not allow any pop-up to appear".
10. Successfully disable pop-up.
Hope it helps. By the way I am Jennielyn Campos from Philippines. I am an Information Technology student for 4 years.
