The vital features of CM Security Antivirus software
What are the best and significant features that can be said to be an exceptional to that of the CM Security Antivirus? Why should I choose the CM security Antivirus ahead of other Antivirus softwares? What do I stand to benefit also aside the use of the CM Security Antivirus App Software? Thank you.
Answered By 5 points N/A #189931
CM Security Antivirus is a free antivirus for Android with advanced feature and prizes that has ranked it higher than any other antivirus.
The first and main feature of this antivirus is, it’s totally free. It doesn’t come with any in-app purchase or ads. It is being updated regularly with all the latest virus update.
Next, it’s lightweight and simple. Even any novice user can go with it without any trouble. It also comes with built-in Android cleaner for having better performance.
CM Security is also able to scan apps while installing and on execution, preventing any possible harms.
It also supports some exciting features like phone tracking, remote controlling, applock etc. It also takes images if anyone tried something suspicious and you can get the image and find out the culprit.
Most of all, it wins all the AV TEST tests with full score, ensuring as one of the best usable antiviruses. You can see the result here.
CM Security can be installed from Google Play.
