Unable to install the 3D CAD design software solidworks 2012
Hello friends,
I have been trying to install the 3D CAD design software solidworks 2012 on my system. I have tried to install it many times, but every time, I am met with an error on my screen. The screenshot of the installing log file is as follows:
Internal error: The Windows Installer for this product component did not run as expected: 1903.
Contact Technical Support.
When contacting Technical Support about installation issues, you will need to provide the installation log files available in this directory. Use the button below to save your logs as a zip file for sending to your support representative.
I uninstalled my antivirus also and then tried to install solidworks again, but I got the same error. I don’t know what this error 1903 means. I have searched a lot for this, but all in vain. If anyone has any idea, please do let me know and help me in getting out of this bad situation. I am badly stuck.
Your comments are awaited.
Regards.
