Is there any way to turn on bios without keyboard ps2?
I'm using ASUS for Pentium 3. I use keyboard ps2. During boot up for Windows XP ( service pack 2 ), It shows a keyboard error. That's why I can't  go through the bios. So, I need a way to get into bios without keyboard ps2.
Can anyone help me?
Answered By 0 points N/A #195640
If you have a PS2 Keyboard, the BIOS should identify the key strokes,you should clear the CMOS and try again. Here is what you have to do:
– Shut down your computer, unplug all the cables from CPU.
– Now press the power button of the computer to waste residual energy.
– Once you have done this open the CPU and remove the CMOS battery on the board for around 10 seconds. I have added a photo of what the battery looks like.
– Now put the battery back, plug in all the cables before you hit the power button. You should be able to enter the Bios now.
