Syntax error in FROM clause
Looking for some piece of advice about what’s going on here.
I used a pivot table in Excel to connect to a table of the external data in access.
I used Microsoft query to return external data to a worksheet in Microsoft excel and every time I view the returned data and I received the following error message:
Syntax error in FROM clause.
I created a pivot table using external data in query or access database. There are no spaces in the names or other oddities that is why the query is extremely small and very simple. I used the very same and exact database on other computer and did not get the error.
Is there something wrong with my coding or it is just the Microsoft query is not functioning well sometimes.
Thank you.
