Specify image dimensions Magento gtmetrix
Hi Guys
I have magento store, but its speed is little bit slow
I visit
http://gtmetrix.com for speed testing,
Major issue what i am facing here : Specify image dimensions
The following image(s) are missing width and/or height attributes.
I just remove actual site name with "mysite.com" so techyv.com don't remove my post.
I check image size by visiting links, images actual dimension is same what you are seeing below, i think i need to edit code, and if you are developer and you have coding skills you can easily judge which file i need to edit.
Advance thanks
