Removing the battery from MacBook
10 points
Posted on - 02/14/2015
Hello, I need to remove the battery from my MacBook to troubleshoot an issue, and the door latch is stuck. I'm afraid to maneuver it too much for fear that it will break and will be stuck forever. Any suggestions or ideas on what to do? I thought maybe it was just sticking but I can't seem to get it to pop open so I can get to the battery. Thanks.
