Question regarding the RSA SNMP Plugin
Hi, I need some advice from those very experienced with this RSA SNMP plugin. I am currently using on SecurID 6.1 and it seems it is not working on this. Whenever the templates are imported, there are no data written or seen. Can anyone suggest any workaround to modify the templates? Thanks.
